Date/Time: Tue, 04 Feb 2025 02:52:27 +0000
[Programming Help] - Study to show only after threshold met?
View Count: 839
[2020-01-02 00:59:32]
osaga - Posts: 53
Hello SC
Is there a way to only make a study show up after a specific threshold (min/max) is met? I know I can use the scale settings to make it appear using a User Defined scale, but is there a Study Subgraph or similar study that will only allow values after a specific threshold (min/max)?
In my case I am using a Study Subgraph to show the difference between 2 moving averages. I want the values to show up only after the difference is 20 ticks or higher. Is this possible?
Thank You!
[2020-01-02 01:13:31]
Ackin - Posts: 1865
Try:
Color Bar Based on Alert Condition
change item "Based On:".... choose "Study Subgraph"
set "Output when condition true (IN4)" ......to "Use Input Data"
alert condition
=IDxx.SG1>=(20*TICKSIZE)
xx is value of the ID Study Subgraph
20 is your tick value
change Drawstyle in the study settings from "Colorbar" to "ValueOnHigh"
change Width to value 8 and more
Date Time Of Last Edit: 2020-01-02 01:47:26
[2020-01-02 01:18:21]
Ackin - Posts: 1865
btw. You are registered on my forum, then for this use the study: "Universal number filter"
Date Time Of Last Edit: 2020-01-02 01:48:15
[2020-01-02 11:38:06]
osaga - Posts: 53
Ackin... thank you again for helping me out. I really appreciate your help and knowledge.
I'm going to check out your universal filter. I do have both of the free scripts installed.
Best Regards
[2020-01-02 11:46:24]
Ackin - Posts: 1865
Oshine)
If you would like to create additional alerts for this purpose, please write your request in the free section suggestions. This study is very simple, a few lines, so it's not a problem to improve it either.
