Date/Time: Sun, 19 May 2024 19:39:02 +0000
Wondering why a spreadsheet study will not show all of the data.
View Count: 524
[2020-01-01 15:30:46] |
User673366 - Posts: 4 |
Been through the documentation several times. I'm sure it probably is something simple, but I'm stumped. Attached a chartbook and an image. Thanks.
Private File Private File |
[2020-01-03 13:03:45] |
We would really need the Spreadsheet file in addition to the Chartbook in order to determine what is happening. One thing to check is the Input on for the Spreadsheet Study for Number of Rows and see if this needs to be increased. Refer to the following: Spreadsheet Study Inputs: Number of Rows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
