Date/Time: Sun, 19 May 2024 15:32:40 +0000
App connects at startup when flag is unchecked
View Count: 531
[2019-12-31 20:54:41] |
User982736 - Posts: 46 |
Version 2017 64 bit Every time I start up Sierra Chart it connects to my data feed even though DTS settings show Connect on Program Startup is unchecked. |
[2019-12-31 21:01:34] |
Your Sierra Chart account is expired. This happens because there is a blank chart in your Chartbook causing a connection to the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-31 22:55:38] |
I don't know how that happened but I closed the charts and started over and it is fine. Thanks. |
