Date/Time: Sun, 19 May 2024 13:24:25 +0000
order fill simulations when using delayed data feed
View Count: 677
[2019-12-31 18:23:57] |
onnb - Posts: 661 |
Environment 1. Using delayed data feed (futures) 2. Trade Simulation Mode On When I place a limit order, I see that the limit order is filled at prices where there was no trading happening. Is this related to the delayed data feed in any way? If you have any documentation on simulating order fills and how that happens, can you please send me a link to that? |
[2019-12-31 18:27:01] |
Whether the data is delayed or not it is not going to affect the order fills. There is some other explanation here. Other than the standard documentation on the Trade Simulation Mode page there is nothing else.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-31 18:27:10
[2019-12-31 18:41:37] |
onnb - Posts: 661 |
got it Trade Simulation: How Orders are Filled In terms of simulating fills, does everything in the link above apply to the new server simulated trading accounts you recently launched |
[2019-12-31 20:42:27] |
Yes.
