Date/Time: Sun, 19 May 2024 12:53:13 +0000
Create My Own Chart Types From Numbers Bars
View Count: 627
[2019-12-31 18:06:14] |
User236924 - Posts: 10 |
Can I take the Numbers Bars information and create my own chart bars. Like for instance, every time the Delta (AskV-BidV) is positive for three consecutive times, it creates a new bullish chart bar. IS THIS POSSIBLE? Big thanks.....
[2019-12-31 18:23:06] |
Yes. Refer to: ACSIL Interface - Custom Chart Bars With this interface you have access to all of the underlying data including Bid Volume and Ask Volume. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-31 18:23:43
