Date/Time: Sun, 19 May 2024 14:46:32 +0000
Daily PL shows incorrect data
View Count: 678
[2019-12-30 19:17:07] |
User840472 - Posts: 15 |
Hello, Ever since switching from CQG Fix to Web a few days ago, the DPL on the DOM shows incorrect data after entering a trade. It starts at zero for the day, but as soon as an order is filled, it changes. The P/L however shows correctly. Everything was working fine before the switch. I have not made any other changes. Thank you. |
[2019-12-30 22:16:37] |
This is explained here: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-31 00:35:34] |
In the Trade Activity Log, Chart Stats, the oldest date for Order Fills Start Date is 12/17/2019. When I go to Chart Settings, Advance settings and set this date for the Order Fills, the DPL doesn't change. I think the problem is that I switched to a new computer and I'm missing a lot of trade fills (because in the Trade Activity Log, when I go to see the fills from 12/17 until today, I don't see all the trades I've made, only a few for 12/17 then it jumps to 12/26). At this point, I just want to reset everything. I'm not concerned about what's missing, I just want the DPL to show correctly and Fills colors to show on the chart correctly (when I set the Chart starting date to 12/17, the fill colors do not correspond to my settings; doesn't differentiate between buy and buy to cover or sell short and sell. But when I use today's date, the colors do show correctly). Is there a way to reset all? Thank you. |
[2020-01-01 05:07:11] |
We do not recommend clearing trade activity data. That is a procedure that we no longer recommend. We just recommend adjusting the Order Fills Start Date-Time to a present time, when the position is flat for the particular symbol and trade account of the chart. And we also recommend using our TT based order routing service to not have any problems with missing order fills: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-01 05:08:05
