Date/Time: Fri, 07 Feb 2025 06:50:58 +0000
[User Discussion] - Chart Calculator Tool DIT incorrect
View Count: 1230
[2019-12-30 19:03:25] |
like2trade - Posts: 117 |
This error only occurs when the data file for a symbol is accumulated in minutes, not ticks, or seconds. The Chart Calculator Tool DIT seems to be calculating incorrectly. It seems to be adding a zero to whatever the result should be. So on a GC chart, instead of measuring 8 ticks, it will show DIT as 80. I have attached an image with an example: http://www.sierrachart.com/image.php?Image=1577732311383.png |
[2020-05-24 03:52:53] |
User427371 - Posts: 14 |
I'm having also having a problem with the CHART CALCULATOR but only with one of my charts...a 30 second chart of 6E. The chart calculator shows every tick as $12.50, even though under chart advanced settings 2 the correct amount is filled in as $6.25 per tick. My other charts of 6E are not having this problem. Today is the first day I've had a problem with the chart caculator not behaving correctly. Date Time Of Last Edit: 2020-05-24 03:53:29
[2020-05-25 11:13:43] |
This is because you are using Chart Trade Mode: Trade Menu: Chart Trade Mode On (Trade menu) Therefore the currency value is multiplied by the order quantity. So change the order quantity for the chart to 1: Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-25 11:13:53
