Date/Time: Sun, 19 May 2024 15:32:46 +0000
historical data
View Count: 479
[2019-12-30 18:57:16] |
hatem hosny - Posts: 57 |
hello, -I noticed that historical data especially the close vary from the intraday data in weekly and monthly time frames.(vary 1 to 7,8 maybe more pips) . can you verify and fix this issue? thank you |
[2019-12-30 20:19:12] |
Refer to: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.6 - Differences Between Close Prices on Historical Daily Charts Compared to Intraday Charts There is no problem here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-30 20:19:26
