Date/Time: Sun, 05 May 2024 18:47:42 +0000
Strange behaviour of sc.AddLineUntilFutureIntersectionEx with range highlight
View Count: 792
[2019-12-30 15:27:44] |
User311344 - Posts: 136 |
Ive noticed a strange behaviour of sc.AddLineUntilFutureIntersectionEx when used with range highlight option as you can see on attached screens. When origin of the range is visible the whole area is highlighted correctly (3 full ticks of range). But when the origin of the range is scrolled outside of screen the highlighted range turns into shrinking separate ranges becoming single lines and totally disappearing at some point. Is this some kind of performance hack or a bug? Same behaviour can be seen using native VolumeArPriceThresholdV2 study with trasnparent range option on. All this makes ranges not properly readable and unintuitive. Could you fixed that? Date Time Of Last Edit: 2019-12-30 21:57:36
range1.jpg / V - Attached On 2019-12-30 15:21:58 UTC - Size: 42.7 KB - 258 views range2.jpg / V - Attached On 2019-12-30 15:22:03 UTC - Size: 12.04 KB - 254 views |
[2020-01-01 00:05:44] |
We will be looking this over.
[2020-02-06 22:34:34] |
Hey it's been a month already and 2043 still plots wrong ranges which dont hold original height of the range but shrink in size. As I said you can easily recreate this problem using native VolumeArPriceThresholdV2 study with range extention option on. Attached you can see the same chart area but with different scroll position and range becomes thiner and thiner lines and finally they disappear, which is obviously very wrong. Please fix this asap. Thank you!!!!!!! Date Time Of Last Edit: 2020-02-06 23:01:04
extproblem.jpg / V - Attached On 2020-02-06 22:59:23 UTC - Size: 93.6 KB - 242 views |
[2020-02-07 21:33:52] |
We will do our best to get to this as soon as possible.
[2020-02-23 11:05:24] |
This problem has been determined and resolved. We are putting out a new release now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-23 11:05:34
