Date/Time: Sun, 19 May 2024 16:25:48 +0000
Data delayed by 10 minutes
View Count: 624
[2019-12-30 15:17:14] |
User814892 - Posts: 3 |
Hi, It appears my CME data is delayed by 10 minutes. I contacted AMP, who said they haven't received any reports and suggested I reach out directly to SC. Could you help me troubleshoot? Thanks! |
[2019-12-30 16:31:28] |
We see you are using SC Data-All Services and unless you are paying for real-time CME data, it will be delayed. If AMP set you up an account on CQG, then use that service: CQG Trading Platform Service AMP will need to help you with CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-30 16:31:41
