Date/Time: Thu, 28 Mar 2024 14:42:11 +0000
[Locked] - Bitmex XBTUSD wrong PNL
View Count: 3472
[2020-06-30 23:08:50] |
User556729 - Posts: 3 |
There is hardly any volume at Coinflex so IMO this isn't really a solution for the problems described above. Being able to backtest BitMEX pairs would be greatly appreciated. As for coin flex, I actually looked at the market data currently provided, I only see futures on there. Will the perpetual swap pairs also be supported in the future? |
[2020-07-01 00:05:50] |
User227811 - Posts: 16 |
I agree. Coinflex doesnt have the liquidity like Bitmex does. It is extremely painful to use Sierra Charts to effective manage risk with the system currently showing the incorrect PNL. I strongly recommend and plead with the Sierra Chart team to fully commit and fix the UPNL/PNL presented when trading on Bitmex. Just please compare volume and user traffic on CoinFlex and Bitmex. You will see who is more of a dominant player in the game. Coinflex has physically delivered futures and it is clear the space isnt trading such instruments at the current given time. I am in love with Sierra but it is difficult to use to trade when PNL is incorrect.
[2020-07-02 08:01:12] |
We have much other higher priority items we need to work on. We cannot allocate time to this now.
[2020-08-01 18:02:32] |
Can you please give a rough estimate as to when you’d be able to allocate some time? This fix isn’t too difficult. I also think it would be good to maybe gauge demand for something like this before just putting it off for months on end. Loyal customer here just looking for the ability to use your platform effectively. |
[2020-08-02 01:27:34] |
Our decision is there is no effort which will be put into this. We have decided not to do anything further with BitMex.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-18 16:22:26
[2020-08-11 03:34:14] |
vish100 - Posts: 111 |
I think being able to export trade activity log in an excel could be a workaround solution but looks like that option is 'greyed out' .. it can only be saved as .txt?
[2020-11-18 15:51:35] |
MuUs! - Posts: 45 |
UP! Any update regarding the proper calculation of PnL for BitMex perpetual XBTUSD? Thanks |
[2020-11-18 16:22:04] |
No update. There is no further development with BitMex. All further development is terminated. This thread is now locked and is a complete waste of our time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-18 16:23:00
