Date/Time: Tue, 04 Feb 2025 02:46:16 +0000
Chart Price Display
View Count: 1220
[2019-12-28 23:38:25] |
User47706 - Posts: 22 |
My Chart prices are displaying as 150.0000, 150.2000, 150.4000, etc.. I want my Chart prices to display with meaningful 100th, 1,000th and 10,000th decimals (eg. 150.0123, 150.2999, etc.). I have made my Price Display Format 0.0001 in Chart Settings. What else do I need to do? |
[2019-12-29 04:09:35] |
We are not understanding this. We do not know where you are seeing those numbers. Specifically where in the chart do you see those?
[2019-12-29 11:53:18] |
In the right-most panel of Region 1 of any chart. This panel corresponds to the Horizontal grid of the chart. I have attached a screen capture. http://www.sierrachart.com/image.php?Image=1577620229808.png |
Capture.PNG / V - Attached On 2019-12-29 11:48:37 UTC - Size: 17.16 KB - 276 views Attachment Deleted. |
[2019-12-29 22:01:34] |
You will need to adjust the Scale Increment setting for the chart as you require: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
