Date/Time: Tue, 29 Sep 2026 12:35:16 +0000
Historical data for more than 10 years
View Count: 3141
[2019-12-28 16:12:16]
User469236 - Posts: 4
How do I load historical futures data for 30 years or longer? So far i'm only able to get up to 10 years. I'm using daily data.
[2019-12-29 04:26:04]
For many of the commodity markets there is futures data going back about 30 years. For what market did you need this for?
Make sure you are using a Continuous Futures Contract chart:
Continuous Futures Contract Charts
[2019-12-30 20:42:41]
I need it for popular futures like ES, YM, NQ, GC, ZB, 6E, CL, ZS, etc.
Yes, I am using Continuous Futures Contract chart and I was able to get it for 20 years. The log shows the following message: "Limiting the number of years to download historical data for to 20 years for the continuous futures chart. Reason: Account Level Limitation." How do I remove the account level limitation?
[2020-01-02 05:44:32]
This limitation is something we are working on. We will try to have this done, in the next couple of days.
Also keep in mind some of those futures contracts are not going to go back further than 20 years because they did not exist. For example the ES.
[2020-01-02 17:38:06]
Thank you. Will you update this ticket when the issue has been resolved?
[2020-01-02 18:58:35]
Yes it should be done tomorrow. But also be aware that historical daily data data queries over a certain number per month will have an extra cost associated with them. The cost is very small and more details will come out later.
[2020-01-06 21:25:03]
Any update on this? Thank you!
[2020-01-07 21:58:17]
This should have been released. But we are checking. You should be able to do continuous contracts back 30 years. Follow the instructions here to re-download the data:
[2020-01-07 23:24:13]
Verified this has been released.
[2021-08-05 22:09:45]
jwick - Posts: 142
Can I confirm if this is supported for intraday data? I am trying to download a continuous back-adjusted contract of the ES but am only seeing data going back to 2008-05-04. Is there a way to get more historical intraday data prior to that point?
[2021-08-05 23:28:44]
No not more historical Intraday data. 2008 is about as far back as the there is available for that type of data.
[2025-04-09 13:03:31]
TonyCipriani - Posts: 153
Hi, I'm trying to load historical intraday data as far back as possible which I believe is 2008, but it's only taking me to Jan 28, 2010. On the message log it says "Limiting the number of years to download historical data to 15 years for the continuous futures contract. Reason: 15 years maximum for intraday charts." I have Days to load for Intraday Chart Data type to 8000. This is for all products, whether it's ES, NQ, GC, etc. I'm also using the Denali data feed. Is there any workaround for this?
Thanks.
[2025-04-09 22:51:54]
Sierra_Chart Engineering - Posts: 25001
You can open individual futures contract charts for a specific month and year which is far back in time. Rather than using the Continuous Futures Contract feature.
Refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Using Expired Futures Contracts
Date Time Of Last Edit: 2025-04-09 22:52:16
[2025-04-10 13:56:06]
Thank you. The only thing is that I'm performing a study, and having to input the settings to check on each individual futures contract makes the task quite tedious. I'm already able to perform this study for the past 15 years on one single chart, but I just need the extra 3-4 years to look at as well. If I were to add them individually, I'd have to manually input settings on maybe around 20+ charts.
Thanks for your help.
[2025-05-06 16:46:04]
We will see what we can do regarding this.
[2025-06-02 16:06:46]
The maximum limit in years for Intraday data for continuous contract charts has been increased in newer versions. Update to the latest version of Sierra Chart.
[2025-10-01 06:44:34]
User562525 - Posts: 35
Can you please increase this to 30 or even 40 years? Why is there a limit at all for how many years we can load? When setting download size to 1 minute bars only the chart loads pretty quickly even with 20 years of data. So please increase to at least 30 years. Thank you.
[2026-05-11 12:54:59]
Yes to reiterate what User562525 in Post #17, say many years down the line in like the year 2035, if we can only load up 20 years of data, that means we can only get data up until 2015. If we already have the data that currently goes to 2008 on these futures, it would be very helpful to increase that to something larger like 40 years.
[2026-05-11 17:13:27]
John - SC Support - Posts: 48044
We are not sure what the limit is on the number of years for a Continuous Contract data. But we can tell you that it currently goes back farther than what we have historical data for. Our oldest data is for the CME Group and goes back to 2008. You can download and display all that data at this time.
