Date/Time: Sun, 19 May 2024 15:52:18 +0000
TT data to Denali data?
View Count: 1388
[2019-12-27 18:37:41] |
User540754 - Posts: 34 |
Hi folks, I was hoping to get some input from the community if there is a huge difference between these data feeds? pros/cons? Thanks! |
[2019-12-27 22:45:15] |
There is a no one among the Sierra Chart user base who is even using the TT data feed. There is a major difference because Sierra Chart only supports the TT FIX data feed, but we discourage its use, and that data feed is not an efficient feed, and has issues with the accuracy of bid volume and ask volume. The TT FIX data feed is not a data feed you will want to use. It is also very expensive. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-27 22:46:08
[2019-12-27 23:48:08] |
Thank you for the advice. I also noticed during my search of the Support Board that CQG is also not recommended. May I ask which ones you find successful in conjunction with Sierra Charts for data? |
[2019-12-28 03:50:04] |
CQG is fine. We just do hear a lot about connectivity related issues with CQG. But you may not be affected by that.
[2019-12-28 04:30:35] |
Back to the original question, what is the reliability like with Denali data versus CQG? What other data providers should I consider with Sierra Charts? Thank you! |
[2019-12-28 05:19:26] |
You are definitively better off using the Denali data feed as compared to the CQG data feed. There is no match from our perspective. So long as you only require CME data. Don't even think twice about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-28 05:20:03
[2019-12-29 19:43:51] |
I would like to make this change to the Denali data feed. Can someone at Sierra Charts help me with the steps to make this change privately? Do I need to notify my broker? Thank you in advance. |
[2019-12-29 22:02:28] |
Yes we will get this done for you. It will be done before the end of the year. No need to notify your broker.
[2019-12-30 04:30:15] |
SC Support - Posts: 1801 |
Hi User540754, I will reach out to by email to set-up the Denali Exchange Data Feed. We can speak also if you want to go through other questions.
