Date/Time: Tue, 04 Feb 2025 02:48:38 +0000
AMP Futures account connection
View Count: 1751
[2019-12-27 16:56:56] |
User557544 - Posts: 3 |
Do you have Live Feed / Historical Data the Hong Kong Exchange / HSI Futures VIA this CQG / AMP account?
[2019-12-27 18:16:30] |
Yes. But why not use the Hong Kong futures data feed from CQG? Refer to: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-27 18:17:02
[2019-12-27 18:49:04] |
Thanks, I'm using CQG because my account is with AMP Futures and am already subscribed to CQG data feeds there and, I also use other platforms than SierraChart ?? |
[2019-12-28 05:10:47] |
Hong Kong futures are definitely supported when using CQG. You will see the symbols in File >> Find Symbol >> Futures.
