Date/Time: Tue, 07 May 2024 15:29:09 +0000
Quote Board Working Some Only
View Count: 459
[2019-12-27 16:50:56] |
Trader_bob - Posts: 1 |
Hello, Today, I changed from the TDA Feed (not supported - I understand that part and have no problem with the decision). I believe that I subscribed (today) to the Sierra Data Feed. The charts and studies come up and successfully link to my quote board. On the quote board, I see the pricing data for Futures and Major Indices, but not individual stocks or ETF's. I understand that the issue is on my end, but have not been able to find the answer. I need Level 2 Quotes Is there a separate data feed that I need to subscribe to for this? Thanks, Robert |
[2019-12-27 17:02:34] |
Everything looks ok with the Sierra Chart Exchange Data Feed on your account. Could you restart Sierra Chart and enable the Force Login option on the Login window. Tell us one of the symbols that is not updating. We do not have a solution for Level 2 data other than using IQ Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-27 17:02:48
