Date/Time: Tue, 07 May 2024 19:54:38 +0000
Number Bars: Background shaded Volume Profile
View Count: 822
[2019-12-26 06:35:39] |
ycomp - Posts: 274 |
How can I enable this background shaded volume profile as in the image?
sierra delta number bars.png / V - Attached On 2019-12-26 06:34:40 UTC - Size: 79.92 KB - 365 views |
[2019-12-26 12:15:49] |
User41683 - Posts: 37 |
Here you go.
Numbers Bar-VP+.StdyCollct - Attached On 2019-12-26 12:13:51 UTC - Size: 18.82 KB - 335 views |
[2019-12-26 15:05:49] |
We are not sure what was done in that Numbers Bars chart. The proper solution is to use the Column # Background Type setting: Numbers Bars: Numbers Bars Background Types You will need to set it to one of the Volume Profile options. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-26 15:06:27
