Date/Time: Tue, 04 Feb 2025 00:48:19 +0000
SC Order Routing Service any other brokers besides AMP?
View Count: 626
[2019-12-25 20:00:14] |
User695518 - Posts: 53 |
Hello, We all know that the SC Order Routing Service works with AMP, but are there any other supported brokers? Any other users out there using other brokers that can confirm? Thanks! |
[2019-12-25 20:01:49] |
Yes there are many other clearing firms you can use. They are all listed here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions The second most common one is going to be Dorman. There is also Advantage and ADMIS. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
