Date/Time: Tue, 07 May 2024 05:02:58 +0000
cant save grahfs
View Count: 863
[2019-12-25 15:37:38] |
User641663 - Posts: 1 |
Hi. after I am setting the graphs I click save and when I open them again it was not save |
[2019-12-26 16:06:52] |
It sounds like you may be confusing Charts with Chartbooks. Only Chartbooks are saved, which contain the individual charts. So if you select Save (to save the Chartbook), but then close a Chart and then save again when closing the program (or selecting File >> Save), then the Chart will be gone. Refer to the following for an understanding of Chartbooks: Chartbooks (Workspaces) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
