Date/Time: Tue, 07 May 2024 18:03:08 +0000
SAI Customed Study
View Count: 486
[2019-12-25 12:11:48] |
SAI Elite - Posts: 12 |
Hello, I am the developer of SAI , which I have given to you to upload the dll.onto SC, it works perfectly on my Terminal and others. Kindly please enable Bill Sherman to the SAI dll. I have enabled him through my terminal , but something does not work right. Many thanks in advance for your kind assistance in this instance. Kind regards, G.Steckel Skype:- G Steckel Date Time Of Last Edit: 2019-12-26 03:50:58
Private File |
[2019-12-26 23:04:48] |
Based on the communication through tickets and email, this issue is resolved. You have built the 64-bit DLL and it is being distributed to your users.
