Date/Time: Tue, 07 May 2024 12:30:22 +0000
Is it possible to close the right side scale?
View Count: 1018
[2019-12-25 03:44:24] |
User784341 - Posts: 6 |
Is it possible to close the right side scale? I just want keep the left side scale on. |
[2019-12-26 23:41:32] |
Yes through Hide Values Scale in the Chart >> Chart Settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-26 23:41:53
[2019-12-26 23:46:45] |
John - SC Support - Posts: 31419 |
You will find the documentation for this setting here: Chart Settings: Hide Values Scale (Chart >> Chart Settings >> Scale menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-27 02:07:22] |
Thanks For your reply! I tried the Hide Values Scale for chart settings, but this option will hide both of the left side scale and the right side. Can i just hide the right side scale and keep the left side scale on ? |
[2019-12-27 15:47:22] |
We have made the change, so that the option for Hide Values Scale only turns off the Right Side Scale. In order to turn off the Left Side Scale, you will then have to deselect the option for Use Left Side Scale. This will be in the next Pre-Release (v 2031). When available, you can use these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
