Date/Time: Tue, 04 Feb 2025 01:02:21 +0000
Alerts
View Count: 494
[2019-12-23 17:28:29] |
User731023 - Posts: 138 |
Is there a way to have only the alerts for the Chartbook you have open/active go off? The ones in the background that are not active also go off. Thanks |
[2019-12-24 19:23:39] |
No, this is not supported. You would need to disable the alerts that you are not interested in at that time.
