Date/Time: Tue, 04 Feb 2025 01:50:32 +0000
DTC Protocol: Struct definitions
View Count: 618
[2019-12-21 16:33:10] |
User654912 - Posts: 26 |
Regarding the new Standard Fixed header file listed here: https://dtcprotocol.org/DTC_Files/DTCProtocol.h In the definition of s_MarketDepthUpdateLevelFloatWithMilliseconds: - Side is defined as int8_t instead of AtBidOrAskEnum8 which is uint8_t - UpdateType is defined as int8_t of MarketDepthUpdateTypeEnum which is uint8_t Cheers |
[2019-12-22 02:14:15] |
This will be corrected in the next release.
