Date/Time: Tue, 04 Feb 2025 01:01:17 +0000
No estoy recibiendo la data de Rithmic, me aparece este error
View Count: 1201
[2019-12-20 17:10:34] |
Taylor0F3 - Posts: 7 |
Triggering next historical data download in queue. | 2019-12-20 11:10:39.343 Requesting market depth updates for: ESH0-CME if supported. | 2019-12-20 11:10:42.937 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2019-12-20 11:10:43.039 Rithmic Trading | Market Depth data has been rejected for symbol: ESH0-CME. get_order_book error : 13. Result text: "permission denied" | 2019-12-20 11:10:43.039 File >> Disconnect selected. | 2019-12-20 11:47:06.764 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-20 11:47:06.768 Rithmic Trading | Disconnected. | 2019-12-20 11:47:06.768 Rithmic Trading | Port for executable: 51649 | 2019-12-20 11:47:18.701 Listening socket (2276). Port 51649 | Closed. | 2019-12-20 11:47:18.701 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-20 11:47:18.703 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51649. Current folder: C:\SierraChart\Rim | 2019-12-20 11:47:18.709 Rithmic Trading | Bridge process is not running! | 2019-12-20 11:47:20.705 Rithmic Trading | Connecting to the server 127.0.0.1. Port 51649 | 2019-12-20 11:47:20.705 DTC Client socket (2) | Creating socket. | 2019-12-20 11:47:20.705 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-20 11:47:20.706 DTC Client socket (2) | Connect event error. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2019-12-20 11:47:22.709 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-20 11:47:22.710 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-20 11:47:22.710 DTC Client socket (2) | Closed. | 2019-12-20 11:47:22.710 Rithmic Trading | Disconnected. | 2019-12-20 11:47:22.718 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-20 11:47:22.718 Rithmic Trading | Port for executable: 51651 | 2019-12-20 11:47:24.723 Listening socket (2352). Port 51651 | Closed. | 2019-12-20 11:47:24.723 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-20 11:47:24.725 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51651. Current folder: C:\SierraChart\Rim | 2019-12-20 11:47:24.734 Rithmic Trading | Bridge process is not running! | 2019-12-20 11:47:26.739 Rithmic Trading | Connecting to the server 127.0.0.1. Port 51651 | 2019-12-20 11:47:26.739 DTC Client socket (2) | Creating socket. | 2019-12-20 11:47:26.740 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-12-20 11:47:26.740 DTC Client socket (1) | Close event error. Windows error code 10053: Se ha anulado una conexión establecida por el software en su equipo host.. | 2019-12-20 11:47:27.455 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-20 11:47:27.455 DTC Client socket (1) | Closed. | 2019-12-20 11:47:27.455 DTC Client socket (2) | Connect event error. Windows error code 10061: No se puede establecer una conexión ya que el equipo de destino denegó expresamente dicha conexión. | 2019-12-20 11:47:28.757 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-12-20 11:47:28.757 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-20 11:47:28.757 DTC Client socket (2) | Closed. | 2019-12-20 11:47:28.757 Rithmic Trading | Disconnected. | 2019-12-20 11:47:28.773 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-12-20 11:47:28.773 Rithmic Trading | Port for executable: 51653 | 2019-12-20 11:47:30.770 Listening socket (2276). Port 51653 | Closed. | 2019-12-20 11:47:30.770 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-12-20 11:47:30.773 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51653. Current folder: C:\SierraChart\Rim | 2019-12-20 11:47:30.783 Rithmic Trading | Bridge process is running. | 2019-12-20 11:47:32.781 Rithmic Trading | Connecting to the server 127.0.0.1. Port 51653 | 2019-12-20 11:47:32.781 DTC Client socket (1) | Creating socket. | 2019-12-20 11:47:32.781 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-12-20 11:47:32.781 Rithmic Trading | Connected to server. | 2019-12-20 11:47:32.785 Rithmic Trading | Starting socket receive thread. | 2019-12-20 11:47:32.785 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-12-20 11:47:32.785 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-12-20 11:47:32.788 Rithmic Trading | Sending logon request message. | 2019-12-20 11:47:32.788 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-12-20 11:47:32.790 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-12-20 11:47:32.795 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-12-20 11:47:32.795 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2019-12-20 11:47:33.889 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2019-12-20 11:47:33.992 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2019-12-20 11:47:34.504 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2019-12-20 11:47:34.606 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2019-12-20 11:47:35.082 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2019-12-20 11:47:35.169 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2019-12-20 11:47:35.671 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2019-12-20 11:47:35.766 Rithmic Trading | Received logon response. | 2019-12-20 11:47:35.790 Rithmic Trading | Server Name: SC DTC Bridge. | 2019-12-20 11:47:35.790 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-12-20 11:47:35.790 Rithmic Trading | Successfully connected. IB='AMP', Firm='AMPClearing'. | 2019-12-20 11:47:35.790 Rithmic Trading | Trading is supported. | 2019-12-20 11:47:35.790 Rithmic Trading | Order cancel and replace is supported. | 2019-12-20 11:47:35.790 Rithmic Trading | OCO Orders supported. | 2019-12-20 11:47:35.790 Rithmic Trading | Connected to data and trading server. | 2019-12-20 11:47:35.790 Triggering next historical data download in queue. | 2019-12-20 11:47:35.790 Triggering next historical data download in queue. | 2019-12-20 11:47:35.790 Triggering next historical data download in queue. | 2019-12-20 11:47:35.790 Triggering next historical data download in queue. | 2019-12-20 11:47:35.790 Rithmic Trading | Starting real-time market data updates for: MESH0-CME. ID: 1 Service code: rithmic.trading | 2019-12-20 11:47:35.798 Rithmic Trading | Requesting security definition data for: MESH0-CME. ID: 1 | 2019-12-20 11:47:35.798 Rithmic Trading | Starting real-time market data updates for: ESH0-CME. ID: 2 Service code: rithmic.trading | 2019-12-20 11:47:35.798 Rithmic Trading | Requesting security definition data for: ESH0-CME. ID: 2 | 2019-12-20 11:47:35.798 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESH0-CME | 2019-12-20 11:47:35.798 Added historical Intraday data request for ESH0-CME to the queue. | 2019-12-20 11:47:35.798 Intraday data recording state for symbol ESH0-CME is set to download 'Pending'. | 2019-12-20 11:47:35.798 Triggering next historical data download in queue. | 2019-12-20 11:47:35.798 Delaying start of download for ESH0-CME | 2019-12-20 11:47:35.800 Rithmic Trading | Starting real-time market data updates for: F.US.MESZ19. ID: 3 | 2019-12-20 11:47:35.867 Rithmic Trading | Requesting security definition data for: F.US.MESZ19. ID: 3 | 2019-12-20 11:47:35.867 Rithmic Trading | Starting real-time market data updates for: F.US.EPZ19. ID: 4 | 2019-12-20 11:47:35.867 Rithmic Trading | Requesting security definition data for: F.US.EPZ19. ID: 4 | 2019-12-20 11:47:35.867 Rithmic Trading | Using primary service for historical data for F.US.EPZ19 | 2019-12-20 11:47:35.867 Added historical Intraday data request for F.US.EPZ19 to the queue. | 2019-12-20 11:47:35.867 Intraday data recording state for symbol F.US.EPZ19 is set to download 'Pending'. | 2019-12-20 11:47:35.867 Triggering next historical data download in queue. | 2019-12-20 11:47:35.867 Delaying start of download for F.US.EPZ19 | 2019-12-20 11:47:35.868 Symbol Error - F.US.MESZ19 is unknown, unavailable, or improperly formatted. | 2019-12-20 11:47:35.868 Symbol Error - F.US.EPZ19 is unknown, unavailable, or improperly formatted. | 2019-12-20 11:47:35.869 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2019-12-20 11:47:36.009 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: MESH0-CME | 2019-12-20 11:47:36.111 Symbol Error - MESH0-CME is unknown, unavailable, or improperly formatted. | 2019-12-20 11:47:36.111 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2019-12-20 11:47:36.112 Symbol Error - ESH0-CME is unknown, unavailable, or improperly formatted. | 2019-12-20 11:47:36.112 HD Request # 18 | Downloading Intraday chart data for ESH0-CME to the file ESH0-CME.scid. Service: cme | 2019-12-20 11:47:36.460 HD Request # 18 | Download start date-time: 2019-12-20 11:00:41.000 | 2019-12-20 11:47:36.461 HD Request # 18 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-12-20 11:47:36.461 Socket (2) | Creating socket. | 2019-12-20 11:47:36.462 Socket (2) | Connecting to IP: 8.18.161.133. | 2019-12-20 11:47:36.462 HD Request # 19 | Downloading Intraday chart data for F.US.EPZ19 to the file F.US.EPZ19.scid. Service: rithmic.trading | 2019-12-20 11:47:36.581 HD Request # 19 | Download start date-time: 2019-11-19 00:51:02.000 | 2019-12-20 11:47:36.583 HD Request # 19 | Sending historical data request. Start date-time: 2019-11-19 00:51:02. Record interval: 0. Symbol: F.US.EPZ19 | 2019-12-20 11:47:36.583 HD Request # 19 | Error downloading historical Intraday data for F.US.EPZ19. Historical data request rejected because the symbol is not valid | 2019-12-20 11:47:36.585 HD Request # 19 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for F.US.EPZ19 | 2019-12-20 11:47:36.585 HD Request # 19 | Completion time: 0s | 2019-12-20 11:47:36.586 HD Request # 19 | Intraday data download complete for F.US.EPZ19. Unique request ID: 18 | 2019-12-20 11:47:36.586 Removed historical data download ID 18 | 2019-12-20 11:47:36.586 Real-time Intraday chart data file updates started for F.US.EPZ19 | 2019-12-20 11:47:36.586 Intraday chart data file opened for F.US.EPZ19 | 2019-12-20 11:47:36.586 Triggering next historical data download in queue. | 2019-12-20 11:47:36.586 HD Request # 18 | Setting DTC encoding to Binary VLS | 2019-12-20 11:47:36.642 HD Request # 18 | Sending historical data logon request message. | 2019-12-20 11:47:36.642 HD Request # 18 | Requesting Intraday data. Start date-time: 2019-12-20 11:00:41. Record interval: 0. Symbol: ESH20 | 2019-12-20 11:47:36.729 HD Request # 18 | Decompressing data. | 2019-12-20 11:47:36.818 HD Request # 18 | Receiving Intraday data for ESH0-CME starting at 2019-12-20 11:00:41 | 2019-12-20 11:47:37.139 HD Request # 18 | Timestamp of first Intraday data file record written: 2019-12-20 11:00:43 | 2019-12-20 11:47:37.141 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-20 11:47:37.366 Historical data download thread signaled to stop. | 2019-12-20 11:47:37.384 HD Request # 18 | Received 36634 records from 2019-12-20 11:00:41.000 to 2019-12-20 11:37:39.020 (37.0 minutes) and wrote 36632 records for ESH0-CME | 2019-12-20 11:47:37.385 HD Request # 18 | Completion time: 0s | 2019-12-20 11:47:37.393 HD Request # 18 | Intraday data download complete for ESH0-CME. Unique request ID: 17 | 2019-12-20 11:47:37.393 Removed historical data download ID 17 | 2019-12-20 11:47:37.393 Real-time Intraday chart data file updates started for ESH0-CME | 2019-12-20 11:47:37.393 Intraday chart data file opened for ESH0-CME | 2019-12-20 11:47:37.393 Rithmic Trading | Using primary service for historical data for ESH0-CME | 2019-12-20 11:47:37.393 Added historical Intraday data request for ESH0-CME to the queue. | 2019-12-20 11:47:37.393 Intraday data recording state for symbol ESH0-CME is set to download 'Pending'. | 2019-12-20 11:47:37.393 Triggering next historical data download in queue. | 2019-12-20 11:47:37.393 Triggering next historical data download in queue. | 2019-12-20 11:47:37.393 HD Request # 20 | Downloading Intraday chart data for ESH0-CME to the file ESH0-CME.scid. Service: rithmic.trading | 2019-12-20 11:47:37.393 HD Request # 20 | Download start date-time: 2019-12-20 11:37:39.000 | 2019-12-20 11:47:37.394 HD Request # 20 | Sending historical data request. Start date-time: 2019-12-20 11:37:39. Record interval: 0. Symbol: ESH0-CME | 2019-12-20 11:47:37.394 Rithmic Trading | Message from server: Requesting historical Tick data. | 2019-12-20 11:47:37.397 Socket (2) | Socket gracefully closed by remote side. | 2019-12-20 11:47:37.452 Socket (2) | Closed. | 2019-12-20 11:47:37.452 HD Request # 20 | Error downloading historical Intraday data for ESH0-CME. Error downloading historical Tick data. Error: permission denied | 2019-12-20 11:47:37.562 HD Request # 20 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESH0-CME | 2019-12-20 11:47:37.562 HD Request # 20 | Completion time: 0s | 2019-12-20 11:47:37.562 HD Request # 20 | Intraday data download complete for ESH0-CME. Unique request ID: 19 | 2019-12-20 11:47:37.562 Removed historical data download ID 19 | 2019-12-20 11:47:37.562 Real-time Intraday chart data file updates started for ESH0-CME | 2019-12-20 11:47:37.562 Intraday chart data file opened for ESH0-CME | 2019-12-20 11:47:37.562 Triggering next historical data download in queue. | 2019-12-20 11:47:37.562 Requesting market depth updates for: ESH0-CME if supported. | 2019-12-20 11:47:40.873 Rithmic Trading | Message from server: Server Alert: get_order_book error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2019-12-20 11:47:41.076 Rithmic Trading | Market Depth data has been rejected for symbol: ESH0-CME. get_order_book error : 13. Result text: "permission denied" | 2019-12-20 11:47:41.076 |
[2019-12-20 17:55:41] |
These are the relevant messages: Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: MESH0-CME | 2019-12-20 11:47:36.111 Symbol Error - MESH0-CME is unknown, unavailable, or improperly formatted. | 2019-12-20 11:47:36.111 Rithmic Trading | Message from server: Server Alert: mrv error : 13. Result text: "permission denied". Related symbol: ESH0-CME | 2019-12-20 11:47:36.112 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-20 17:56:07
[2019-12-20 19:20:31] |
Me he contactado con mi broker (Amp Futures) y ya me resolvieron el problema. Muchas gracias.
[2019-12-24 04:20:55] |
Sierra_Chart Engineering - Posts: 18237 |
That is good.
