Date/Time: Tue, 04 Feb 2025 01:48:35 +0000
Copy Studies from chart to another with same symbol
View Count: 1575
[2019-12-20 15:46:10]
User758458 - Posts: 4
Sorry to bother you but i can't copy the studies from one chart to another.
I'm using a FDAX Globex chart with the VWAP 1h, I would like to be able to copy this VWAP1H (chart# 1) on my FDAX chart (# 16) 8h-22h.
But I can't do it, while the copies of the drawings (line, rectangle, etc...) on the Globex are also well represented on the other #16.
How can we make a copy of one or more studies from chart to another chart?
Thanks in advance for your help
Regards
[2019-12-22 22:14:54]
Refer to this study:
Study/Price Overlay Study
Also, if you are just wanting to have the same studies on both charts, and not necessarily the data from one displayed on another, then refer to using Study Collections along with Chart Linking. Here is where you will find the information on Study Collections:
Study Collections
And here is the information on Chart Linking (be sure to read the section for linking Studies):
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
[2019-12-23 08:33:07]
the studiePriceOverlay works perfectly.
I can now combine my Vwap 8h and my Vwap 1H on the same Graph.
Thanks for your help
