Date/Time: Tue, 04 Feb 2025 01:43:30 +0000
Data/Trade services - AMP integration
View Count: 638
[2019-12-20 14:56:09]
grayfrog - Posts: 43
Good morning,
Read the Data/Trade services page as well as some forum posts but I'm still a bit confused. Under the "seamless integration of the Sierra Chart Exchange Data Feed with any of these services" AMP is not listed. Clearly AMP is a FCM and lots of people use AMP seamlessly with Sierra but I suppose I'm confused regarding the difference in Trading service and clearing/broker as pertains to this "seamless integration".
In what instance would one need this integration that isn't the same as with AMP if they are using Sierra for their charting and order execution?
Obviously AMP is integrated with Sierra. What exactly am I missing?
Thank you for your time.
[2019-12-20 15:09:31]
Your question is not making sense to us.
But let us just get to the basic objective. So you want to use Sierra Chart with your AMP account? Is your account set up on CQG or TT with AMP?
[2019-12-20 15:16:01]
Not a problem at all. I understand enough and don't want to waste your time.
Have a good day.
[2019-12-20 15:37:51]
I assume it needs to be set to TT with AMP correct to use the Sierra Data feed and order routing?
[2019-12-21 05:26:26]
Yes this is correct. Instructions are on this page:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions
