Date/Time: Tue, 04 Feb 2025 01:59:11 +0000
futures ticker symbol
View Count: 774
[2019-12-20 02:17:08] |
sectel - Posts: 12 |
Confused....what ticker symbol represents the EURO/US pair for futures under Sierra???
[2019-12-20 05:29:29] |
It depends upon the particular data or trading service being used. We see you are using Interactive Brokers so the symbol begins with EUR-. You can find it in File >> Find Symbol >> Futures-CME.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-20 05:29:45
