Date/Time: Tue, 04 Feb 2025 01:59:48 +0000
bitstamp market deph historical data problem
View Count: 877
[2019-12-19 20:38:31] |
User719206 - Posts: 93 |
Hello, i don't know if i did something wrong or if there is a bug on the market deph historical graph for the bitstamp data on the pair BTCUSD,but, I get values only each 10 € level ( 7100 , 7110 , 7120 ... ) as you can see in the picture below. Can you help me please ? http://www.sierrachart.com/image.php?Image=1576787814780.png |
bitstamp.png / V - Attached On 2019-12-19 20:30:50 UTC - Size: 71.4 KB - 242 views |
[2019-12-20 22:14:44] |
Yes this does make sense because there is combining of market depth levels due to the enormous amount of levels of market depth data that exist. We are going to make some changes to the combine algorithm, over the weekend which will make the combining increment possibly less. You should really be using BitMex symbols instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-20 22:14:59
