Date/Time: Tue, 04 Feb 2025 02:04:58 +0000
problem with switch from CQG-FIX to CQG-Web-API
View Count: 635
[2019-12-19 18:53:01] |
User968981 - Posts: 5 |
After upgrading the software with CQG_Web-API I cannot connect anymore to Sierra Chart. I am not subscribed to CQG Web-API I only use CQG-FIX. CQG Web-API also includes DATA while I am only buying and using SierraChart DATA from the beginning of using SierraChart. Can I revert my software upgrade and only use CQG-FIX (until 12/31/2019)? |
[2019-12-19 19:13:08] |
Yes you can. You can go back to a prior version. Here are instructions: Software Download: Software Rollback Procedure But you do need to ask your broker to enable the CQG Web API effective next month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
