Date/Time: Tue, 04 Feb 2025 01:55:58 +0000
Question about Moving Average Calculation
View Count: 822
[2019-12-19 15:05:35]
User718585 - Posts: 32
Do you know which input data setting has the following formula? I want to do a simple moving average using the following ((H+L+C+C)*.25 and an Exponential moving average using the same formula ((H+L+C+C)*.25
Also, I need a Triangular moving average using the following = ((H+L+C)/3
[2019-12-19 15:42:32]
Sierra_Chart Engineering - Posts: 18237
This is not supported:
((H+L+C+C)*.25
You will need to create your own custom study:
Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL))
For the Triangular Average, refer to:
Moving Average - Triangular
Set the Input Data to HLC Avg.
[2019-12-19 15:49:49]
Ackin - Posts: 1865
User718585)
you can download it as a finished ACSIL study
Study: "Calculation"
contact link:
Date Time Of Last Edit: 2020-06-24 22:49:59
[2019-12-19 16:00:49]
Ok awesome. Where do i go to download the Study: Calculation?
