Date/Time: Tue, 04 Feb 2025 01:50:11 +0000
[User Discussion] - Print a number above a bar
View Count: 890
[2019-12-18 17:39:36]
grantx - Posts: 244
Let say I have a bar that closes above the prior bar high.
How would I print a number or text above that bar?
I would like the indicator to go back through the chart and highlight all bar breakouts.
Could be inside bars. Could be outside bars. Whatever. I would just like to get that condition noted above that particular bar.
[2019-12-18 18:24:14]
Ackin - Posts: 1865
1) Add SCH study
Color Bar Based on Alert Condition
2) To alert window write formula:
=C>H[-1]
3) In the study settings >> Subgraphs tabs Change Drawstyle from ColorBar to xxx (for example Point on High)
[2019-12-18 18:27:14]
Ackin - Posts: 1865
I find it too simple. If you mean something else, describe more and there is no problem to finish the ACSIL study for it.
[2019-12-18 18:59:41]
grantx - Posts: 244
Thank you so much Ackin. Works perfectly!
To draw a '2' I had to set the drawstyle to 'Text' and then enter the 2 in the 'Text to draw' field.
[2019-12-20 10:18:26]
Ackin - Posts: 1865
Hi grantx,
I've worked on it a little bit and made some improvements. The values ​​are in ticks from the previous point. I am currently testing yet another study which is a visualization of this in a summary for the period.
You can download it as a finished ACSIL study
Study: "Break Prior High Low"
contact link:
Date Time Of Last Edit: 2020-06-24 22:51:11
