Date/Time: Tue, 04 Feb 2025 02:05:05 +0000
Varying market depth code
View Count: 581
[2019-12-18 16:28:40] |
JYohan - Posts: 25 |
Hello, I'm currently coding a market depth study and was wondering if it's possible to analyze different market levels? For instance, can I set my chart and SC set to 10 market depth levels but have 1 study use 5 levels? If so, do you know the function to accomplish this? Thanks |
[2019-12-19 04:09:02] |
The study has full access to market depth data and can work with whatever number of levels it wants: ACSIL Programming Concepts: Programmatically Accessing Historical and Current Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-19 04:09:09
