Date/Time: Mon, 25 Nov 2024 00:43:25 +0000
[User Discussion] - Chartbook glitch?
View Count: 1225
[2013-12-30 08:12:39]
100 - Posts: 147
I have a chartbook which may have glitches. Everytime I load the chartbook, the data which is loaded, is always cut off, and I have to delete and redownload the data. In addition, the chartbook is unnecessarily slow. Has anyone run into issues like this? What would you suggest doing to fix the chartbook? Should I just scrap the chartbook and rebuild it from scratch t avoid the glitch?
Note: I have run into issues like this b4 with glitched spreadsheets.
& I've had to delete them and recreate them.
I'm just wondering if there is something I can do to repair them.
Examples: If I recalculate a chart, the data in the chart
immediately cuts back to the start of the day.
At all times the chart is absurdly slow.
Significantly slower than it was yesterday.
Is this a result of a damaged chartbook, chart, or spreadsheet?
If I rebuild this and use the same spreadsheets, will it glitch again?
Date Time Of Last Edit: 2013-12-30 08:22:54
[2013-12-30 10:22:58]
Refer to help topic 42:
Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html
Refer to help topic 30:
Http://www.sierrachart.com/index.php?l=doc/helpdetails30.html
How can we answer this question? You are in a better position to answer it then we can. Refer to help topic 30 for what can cause slow performance. Also the idea that a Chartbook, chart or spreadsheet being "damaged", does not make sense.
Date Time Of Last Edit: 2013-12-30 10:23:22
[2013-12-30 20:16:38]
100 - Posts: 147
Just wanted to follow through and say, I figured it out.
I had maxed out 17gb of dram :).
Turned my computer off and on several! times, and everythings fine.
Sorry, there was no glitch! sc is awesome! MC & HN
