Date/Time: Tue, 04 Feb 2025 00:49:39 +0000
ES Chart crash
View Count: 728
[2019-12-18 15:21:18]
User897008 - Posts: 48
Reading Internal Order ID file. | 2019-12-18 09:19:58.041
Reading Trade Orders file. | 2019-12-18 09:19:58.107
Reading Trade Positions file. | 2019-12-18 09:19:58.108
Reading Account Balance file. | 2019-12-18 09:19:58.108
UDPListener (1012). Port 22903 | Listening on UDP port 22903. | 2019-12-18 09:19:58.123
Software version: 2028 64-bit | 2019-12-18 09:19:58.123
Usage end date: 2020-07-26 | 2019-12-18 09:19:58.123
Enabled for: Advanced Features 2. | 2019-12-18 09:19:58.123
Enabled for: Sierra Chart Historical Data Service. | 2019-12-18 09:19:58.123
Enabled for: Denali Real-Time Exchange Data Feed. | 2019-12-18 09:19:58.123
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2019-12-18 09:19:58.123
Enabled for exchange2: CME (Trading Account Required) | 2019-12-18 09:19:58.123
Enabled for exchange2: CBOT (Trading Account Required) | 2019-12-18 09:19:58.123
Enabled for exchange2: COMEX (Trading Account Required) | 2019-12-18 09:19:58.123
Enabled for exchange2: NYMEX (Trading Account Required) | 2019-12-18 09:19:58.123
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-12-18 09:19:58.123
Current selected Data/Trading service: TransAct WS | 2019-12-18 09:19:58.123
Custom symbol settings values: disabled | 2019-12-18 09:19:58.123
Chart Update Interval: 50 | 2019-12-18 09:19:58.123
Intraday Data Storage Time Unit: 0 | 2019-12-18 09:19:58.123
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-12-18 09:19:58.123
2019-12-18 09:19:58 Local computer time | 2019-12-18 09:19:58.123
2019-12-18 14:19:58 Local computer time in UTC | 2019-12-18 09:19:58.123
2019-12-18 09:19:58 Local computer time in SC Time Zone | 2019-12-18 09:19:58.123
2019-12-18 14:19:57 Server time in UTC | 2019-12-18 09:19:58.123
Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-12-18 09:19:58.123
Program path: C:\SierraChart\ | 2019-12-18 09:19:58.123
Data Files path: C:\SierraChart\Data\ | 2019-12-18 09:19:58.123
OS Version Number: 10.0 | 2019-12-18 09:19:58.124
Locale Setting: C | 2019-12-18 09:19:58.124
DLLs: XXXXXXXXXXXXXXXXXXXXXXXXXXX | 2019-12-18 09:19:58.124
: Array is unallocated. | 2019-12-18 10:16:29.659 *
Chart #8 | Base Graph ID: 0 EndingDateTime: Array is unallocated. | 2019-12-18 10:16:29.660 *
Array message repeat count limit reached. | 2019-12-18 10:16:29.660 *
MESH0[M] Flex Renko 6-5-0 #2 | Performing a full recalculation because it has been tagged. Chartbook: S3_MES.Cht | 2019-12-18 10:16:31.528
Date Time Of Last Edit: 2019-12-18 15:23:36
[2019-12-18 15:23:59]
Sierra_Chart Engineering - Posts: 18237
What do you mean by "crash"?
Date Time Of Last Edit: 2019-12-18 15:24:07
[2019-12-18 15:27:18]
When I modify one chart in this chartbook, another chart in this chartbook changed it's display. Similar charbook like NQ RTY works fine.
[2019-12-18 20:34:55]
Can you please attach that Chartbook by following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
It looks like you are using some custom studies. We will not be able to test those , in the case of where they are having some unexpected effect.
Date Time Of Last Edit: 2019-12-18 20:35:12
[2019-12-19 03:33:08]
When i modified the ID30 or ID31 settings in chart#4 in this chartbook, then the chart#1 will change.
Private File
[2019-12-24 18:47:19]
We are not able to reproduce this error when testing your Chartbook under our debugger:
: Array is unallocated. | 2019-12-19 10:44:35.853 *
We are not sure why this is the case.
Troubleshooting any other problem with your charts or study configuration is not within the scope of our support.
Date Time Of Last Edit: 2019-12-24 18:47:41
