Date/Time: Tue, 25 Feb 2025 04:26:13 +0000
Display price at cross hairs
View Count: 1645
[2019-12-17 15:38:56] |
User97684 - Posts: 136 |
Hi, Is it possible to display price at cross hairs position? pls see picture, Many thanks |
[2019-12-18 04:24:06] |
No, it not supported to display the price at the intersection of the crosshairs. Just to make sure you are aware that the price is displayed in the Tool Values Window and the Compact Tool Values Window, if you have them displayed. Refer to the following: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Also, the price is displayed in the Price Scale on the right as long as the option to display it is enabled. Refer to the following: Chart Drawing Tools: Chart Values Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-04-04 05:11:04] |
User645654 - Posts: 4 |
how can i achieve the same result as you have in ur chart regarding the lock fill area to have drawings at the end , thanks in advance check the chart bellow |
Attachment Deleted. ![]() |
[2021-04-04 16:55:40] |
Hi, in the the graph settings of the studies there is an option ( where is line/dash/hidden etc ) - draw from last bar to end. I create a 'Line' study - with just a price figure and use ' draw from last bar to end'
[2021-04-04 17:14:00] |
thanks, but how do u make it look like a rectangle ? also do you use study overlay to get it from another chart, or everything is in one chart? can u share ur chartbook?
Date Time Of Last Edit: 2021-04-04 17:19:22
