Date/Time: Tue, 04 Feb 2025 00:11:50 +0000
Trailing Stop
View Count: 1076
[2019-12-17 14:47:15] |
AlekMiro - Posts: 4 |
Hello, 1. Can I set a Trailing Stop through the Sierra Chart terminal in Bitmex? When I placed a Trailing Stop in the Sierra Chart terminal, I created a Stop Market order in Bitmex, why so? 2. Can I set a Trailing Stop through the Sierra Chart terminal in Deribit? Aleksandr |
Screenshot_20191215-233528.png / V - Attached On 2019-12-17 14:44:16 UTC - Size: 691.07 KB - 258 views Screenshot_20191215-233738.png / V - Attached On 2019-12-17 14:44:35 UTC - Size: 707.26 KB - 258 views Screenshot_20191215-233750.png / V - Attached On 2019-12-17 14:44:52 UTC - Size: 687.54 KB - 237 views |
[2019-12-18 04:23:03] |
No, this is not supported. Refer to: Order Types: Sierra Chart Management of Trailing Stop and Chase Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-18 13:14:47] |
Hello, Can I configure a Sierra Chart terminal for Trailing Stop in Bitmex? Aleksandr |
Screenshot_20191218-230918.png / V - Attached On 2019-12-18 13:11:51 UTC - Size: 440.27 KB - 260 views Attachment Deleted. |
[2019-12-18 20:56:04] |
No this is not supported.
