Date/Time: Fri, 18 Jul 2025 22:46:54 +0000
Crude Oil Nymex - Rollover
View Count: 1403
[2019-12-17 14:20:56] |
T44 - Posts: 363 |
I'm using the SC data feed with TT routing. SC v 2024. Yesterday and today CL stayed on January 2020 despite having Automatically Rollover Futures Symbol checked. I make 5 business days before the 25th to be yesterday, 16 December. |
[2019-12-17 16:43:17] |
Yes this does make sense if the chart was not reloaded. Refer to the documentation for that setting here: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-17 16:43:31
[2019-12-17 16:55:25] |
T44 - Posts: 363 |
The rollover will only occur when the Chartbook the chart is contained within is opened or the chart is reloaded with Chart >> Reload and Recalculate.
Does closing and re-opening Sierra count as opening a Chartbook? In which case it should have rolled itself and didn't? |
[2019-12-18 04:32:43] |
Based on this rule: 5 business days before the 25th (or preceding business day) before the contract month. The rollover will not be done until December 18. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-18 04:36:06
[2019-12-18 10:54:18] |
T44 - Posts: 363 |
Thank you. I'm aware that the pace of the roll can vary in energies - yesterday 17th Jan 2020 traded 147k lots and February 401k, but the date rule won't roll until the 19th. So I'm probably looking for this option? General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) Question: if I have a symbol limit of 20 and am using 15 symbols, is enabling this option going to cause me to pull real time data for 30 symbols? I am now seeing "Over Symbol Limit, Limit is 20 Symbols" messages. Edit: have upgraded to 100 symbols and the crude oil charts are now rolling based on volume, thanks. Date Time Of Last Edit: 2019-12-18 11:19:04
[2019-12-18 11:56:27] |
T44 - Posts: 363 |
This worked for a few minutes, I restarted Sierra (to upgrade to 2028) and now it is telling me again "Over symbol limit. Limit is 20 symbols. " Yet I have already paid the upgrade and it was working before I upgraded to 2028. Date Time Of Last Edit: 2019-12-18 11:57:37
[2019-12-24 00:49:39] |
Regarding post #6 and #7, yes you do want to use that option, and we already addressed the symbol limit issue in another thread.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-24 00:49:55
