Date/Time: Tue, 04 Feb 2025 00:11:40 +0000
Setting Chart to Today's Date
View Count: 890
[2019-12-17 10:41:53]
ycomp - Posts: 321
How do you change the Date Range to load from today's date starting backwards?
see attached
it is showing august
it is Sierra data feed (free) Forex data
in the screnshot "Use Number of Days to load' is not checked but when it is it still does not change to today 12/17
All my futures charts load from today going backwards to # of days to load fine
image2019-12-17_18-38-36-264.png / V - Attached On 2019-12-17 10:39:25 UTC - Size: 23.04 KB - 239 views
[2019-12-17 11:46:02]
User907968 - Posts: 825
Does that not just mean that 2019-08-21 is the last record in the data file?
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DateRangeInFile
Maybe you need to reconnect and downlaod more data?
'Use Number of Days to load' is what I am using to achieve what you ask.
Date Time Of Last Edit: 2019-12-17 11:46:52
[2019-12-17 12:18:55]
ycomp - Posts: 321
how can I get it to download more data? It takes a long time for Forex (much longer than futures) and I don't need data that is from the summer... just recent data
yes 'use number of days' is what I usually use, it just wasn't on the screenshot because I was trying to fix the problem using the other method of loading data.
but use number of days also has the greyed out value as a date in August
Date Time Of Last Edit: 2019-12-17 12:20:27
[2019-12-17 13:15:41]
I assumed (probably wrongly) that you were simply disconnected from the data feed, hence no new data, maybe I am wrong?
You could just change the 'Max Number of Days to Download'
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxHistoricalIntradayDaysToDownload
Yes, because it is the last date in the file and you can't change it.
[2019-12-17 13:26:07]
Follow the instructions here to improve download performance:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance
