Date/Time: Tue, 04 Feb 2025 00:01:33 +0000
Profit/Loss values displayed on chart and in Trade Activity Log are incorrect
View Count: 791
[2019-12-17 09:48:35] |
samual sprat - Posts: 343 |
Hi, Somewhere since sierra version 2021 the Profit/Loss values displayed on chart and in Trade Activity Log are displaying incorrect values. So for example, I trade CL and it's tick value is $10. Commission I pay for CL is $4.56. If I close a single contract trade +4 ticks, it should show $40 profit without commissions enabled or $35.44 with commissions. Instead the without commissions value is displayed as $30.31 and with commissions is $26.89 (so $3.42 is being used for commissions here for some reason instead of $4.56). These incorrect values are same in TAL or on chart with Show Order Fills enabled. I've checked global symbol settings and Currency Value per tick is set to $10 and Use Global Round Turn Commissions is set to $4.56. Not sure if there is anything else I need to check to make sure my settings are correct but I don't remember changing anything? Thanks S Date Time Of Last Edit: 2019-12-17 09:50:17
[2019-12-17 13:51:20] |
There is definitively not a problem a newer versions. You need to show us a screenshot of what you are referring to, then we will provide you more information. Maybe it is converted to a different currency. For complete documentation on this subject, refer to: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-17 19:15:44] |
Not sure how it happened but that was it thanks, it was set to GBP instead of USD in Trade Settings
