Date/Time: Tue, 04 Nov 2025 18:18:10 +0000
sc.GetStartOfPeriodForDateTime does not work
View Count: 2738
[2013-04-12 15:32:06]
GmA - Posts: 20
Hello Support board!
I have tried to use sc.GetStartOfPeriodForDateTime function, but it always returns incorrect result.
Code is the following:
#include "sierrachart.h"
SCDLLName("Test")
SCString     MessageString;
SCSFExport scsf_Test(SCStudyGraphRef sc)
SCDateTime dtDayStartDateTime;
int    iYear;
int iMonth;
int    iDay;
int    iHour;
int    iMinute;
int    iSecond;
if (sc.SetDefaults)
   sc.GraphName     = "Test";
   sc.FreeDLL     = 1;
   sc.AutoLoop     = 1;
   sc.ScaleRangeType = SCALE_SAMEASREGION;
   return;
if (sc.GetBarHasClosedStatus(sc.Index)!=BHCS_BAR_HAS_CLOSED)
   return;
dtDayStartDateTime  = sc.GetStartOfPeriodForDateTime(sc.BaseDateTimeIn[sc.Index], TIME_PERIOD_LENGTH_UNIT_DAYS, 1, 0);
dtDayStartDateTime.GetDateTimeYMDHMS(iYear, iMonth, iDay, iHour, iMinute, iSecond);
MessageString.Format(" sc.Index = %d, Session Start time = = %.2d.%.2d.%d %.2d : %.2d ", sc.Index, iDay, iMonth, iYear, iHour, iMinute);
sc.AddMessageToLog(MessageString,0);
Log looks as follow:
Chart: ESM3 30 min #1 | Study: Test | sc.Index = 0, Session Start time = = 01.01.1950 00 : 00 | 2013-04-12 09:49:25
Chart: ESM3 30 min #1 | Study: Test | sc.Index = 1, Session Start time = = 01.01.1950 00 : 00 | 2013-04-12 09:49:25
Chart: ESM3 30 min #1 | Study: Test | sc.Index = 2, Session Start time = = 01.01.1950 00 : 00 | 2013-04-12 09:49:25
Chart: ESM3 30 min #1 | Study: Test | sc.Index = 3, Session Start time = = 01.01.1950 00 : 00 | 2013-04-12 09:49:25
Chart: ESM3 30 min #1 | Study: Test | sc.Index = 4, Session Start time = = 01.01.1950 00 : 00 | 2013-04-12 09:49:25
Chart: ESM3 30 min #1 | Study: Test | sc.Index = 5, Session Start time = = 01.01.1950 00 : 00 | 2013-04-12 09:49:25
Same output till sc.Index == 6000.
Build log:
-- Starting build of Custom Studies Source File: Test.cpp. -- 18:49:18
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\SierraChartTransActMA\ACS_Source\Test.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\SierraChartTransActMA\Data\Test.dll"
-- End of Build -- 18:49:19
Theere is an old posts were similar problem with that function was described and as a resolution VC compiler were proposed to be used.
https://www.sierrachart.com/supportboard/showthread.php?t=40023&highlight=GetStartOfPeriodForDateTime
I've tried to compile it by Visual C++ Express, but result is the same.
Current version is 961.
Please advice how to make it working.
Thanks in advance and
Br GmA
[2013-04-12 17:33:29]
We do see this problem using the g++.exe compiler. We have resolved this. We do not see it with Visual C++ 2010. If you do see it using Visual C++, we tend to suspect you are actually not using the DLL generated by Visual C++. And instead using the one from g++.exe.
We will have a new release out today.
[2013-04-13 15:16:27]
GmA - Posts: 20
DLL has been removed from Data directory before compiling by Visual C++, so there were no former one created by g++.
Anyways, todays's version 964 has solved the problem.
Thank you very much for the fast reply and correction.
Regards,
GmA
