Date/Time: Mon, 03 Feb 2025 22:41:13 +0000
Sierra Charts on Macbook (how to import chart files using Parrallels)
View Count: 762
[2019-12-16 11:49:27] |
Chadly - Posts: 65 |
Good morning! I have some friends that use Macs (I know...I'm sorry for that) they have difficulty taking importing the charts I send them via email. Basically unable to find the file to simply drag and drop into for Sierra charts to then have them in the data file. For me, it's easy as I just simply open This PC find the parent file, find the data file then drag and drop the downloaded chart and boom I'm done. How do they do this on a Mac since they have to use an emulator like Parellels? THanks Chadly |
[2019-12-16 15:55:14] |
Use this method to share a Chartbook: File Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
