Date/Time: Mon, 03 Feb 2025 22:48:12 +0000
v2027 issue with GER30 symbol
View Count: 841
[2019-12-16 08:45:32] |
Marmany - Posts: 308 |
Updated from v2005 to v 2027. Chart set to CFD Dax symbol (GER30) now reverts to a blank chart set to GEZ29_FUT_CME (Eurodollar-CME) when Sierra platform is closed then re-opened. Can not find the reason in Global Symbol Settings. Other CFD symbols e.g. Bund and EUSTX50 display correctly, as did the Dax in previous versions. Please advise. |
[2019-12-16 09:30:20] |
User365411 - Posts: 192 |
rel 2007 to rel 2027 Same problem here Date Time Of Last Edit: 2019-12-16 09:31:20
[2019-12-16 11:11:10] |
We are resolving this now and will be releasing version 2028.
