Date/Time: Sun, 24 Nov 2024 23:48:29 +0000
Reading values from Excel into Sierra Charts
View Count: 1606
[2013-12-29 07:35:39]
Nestor Dominguez - Posts: 2
I was wondering if you could help me do the following:
I have some calculated values stored in Excel (for example VAH, POC, and VAL - as well as others) and I would like to have the ability to retrieve the specified values from my excel spreadsheet and plot each of them on a chart as a continuous horizontal line. Can this be done by using your Spreadsheet tool? If not, is there a way to accomplish this task without creating a customized '3rd-party" indicator?
Your response will be deeply appreciated.
thanks
Nestor
[2013-12-29 07:40:32]
Yes this can be done by using the Spreadsheet Study and setting it to Use Excel. Refer to Spreadsheets in the documentation:
http://www.sierrachart.com/index.php?l=doc/doc_WorksheetStudy.html
However, it is strongly preferred that you read this data from the built-in Sierra Chart spreadsheets, for reliability. So if you are able to enter this data or calculate this data using Sierra Chart spreadsheets that would be better.
Date Time Of Last Edit: 2013-12-29 07:40:56
