Date/Time: Wed, 05 Nov 2025 05:51:59 +0000
historical asain futures
View Count: 1191
| [2013-12-28 20:48:22] |
| cmb999 - Posts: 211 |
hello i see N225 (Osaka) and HSI (HKFE) futures listed in the symbol lookup for sc historical data service. But, they do not load any data, when I pull up chart . . |
| [2013-12-29 01:28:51] |
Only Historical Daily data is available. So you can only use these symbols to open "Historical" charts. This is an example symbol format you should be using: HSH14 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
