Date/Time: Fri, 16 Oct 2026 04:31:59 +0000
[Programming Help] - Trial user: only able to apply study against current bar
View Count: 907
[2019-12-13 04:20:45]
mm3599 - Posts: 15
Hello -
I am trialing SC.
I have written a custom function that is referenced by a custom study that I added to ExampleCustomStudies.cpp.
The study only appears to be passing in the current bar's data and not starting from bar zero.
The logging I have written only shows the last bar's index in the Message Log UI.
MACDP Fast Function
SCFloatArrayRef MACDPFast(SCStudyGraphRef sc, SCBaseDataRef BaseDataIn, SCFloatArrayRef Out, int Index, float Fast)
  //fastEMA[0]=((2.0 / (1 + Fast)) * Close[0] + (1 - (2.0 / (1 + Fast))) * fastEMA[1]);
  // fast_part_1_calc = (2.0 / (1 + Fast)) * Close[0]
  // fast_part_2_calc = (1 - (2.0 / (1 + Fast)))
  // fast_part_3_value = Subgraph_MACDP_Fast[1]
  SCString Output;
  sc.FormatString(Output, "Index=%i,Fast=%f", Index,Fast);
  sc.AddMessageToLog(Output, 0);
  if (Index <= Fast)
    Out[Index] = BaseDataIn[SC_LAST][Index];
  else if (Index > Fast)
    float fast_part_1_calc = (2.0 / (1 + Fast)) * BaseDataIn[SC_LAST][Index-1];
    float fast_part_2_calc = (1 - (2.0 / (1 + Fast)));
    Out[Index] = fast_part_1_calc + (fast_part_2_calc * Out[Index - 1]);
  return Out;
Here's the calling code:
SCSFExport scsf_MACDP(SCStudyGraphRef sc)
  SCSubgraphRef Subgraph_MACDP = sc.Subgraph[0];
  SCFloatArrayRef Array_MACDP_Fast = sc.Subgraph[0].Arrays[0];
  //SCSubgraphRef Subgraph_SMA_Demin = sc.Subgraph[4];
  if (sc.SetDefaults)
    sc.GraphName = "MACDP Rev 1";
    sc.StudyDescription = "MACDP calc test.";
    sc.AutoLoop = 1; // true
    sc.FreeDLL = 0;
    sc.GraphRegion = 0;
    Subgraph_MACDP.Name = "MACDP";
    Subgraph_MACDP.PrimaryColor = RGB(255,0,0); // Red
    Subgraph_MACDP.DrawStyle = DRAWSTYLE_LINE;
    return;
  float fast, slow, smooth, macdp_value;
  fast  = 8.3897;
  slow = 17.5185;
  smooth = 9.0503;
  macdp_value = 0.0;
  //calculate the fast value for the macdp
  sc.DataStartIndex = 18;
  MACDPFast(sc, sc.BaseDataIn, Array_MACDP_Fast, sc.Index, fast);
  SCString Output;
  sc.FormatString(Output, "Array_MACDP_Fast[sc.Index]=%f,Array_MACDP_Fast[sc.Index-1]=%f", Array_MACDP_Fast[sc.Index],Array_MACDP_Fast[sc.Index-1]);
Here a sample log output:
Chart: ES-201912-GLOBEX 30000 Trades #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=inf,Array_MACDP_Fast[sc.Index-1]=inf | 2019-12-12 23:17:09.508
Chart: ES-201912-GLOBEX 30000 Trades #1 | Study: MACDP Rev 1 | Index=1317,Fast=8.389700 | 2019-12-12 23:17:10.526
[2019-12-13 16:28:25]
User907968 - Posts: 885
I just copied and pasted your code, then compiled, seems to work as intended (starts calculation from index = 0).
This is an example of what I see, after scrolling almost to the top of the message log:
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=0,Fast=8.389700 | 2019-12-13 10:22:12.621
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.070000,Array_MACDP_Fast[sc.Index-1]=59.070000 | 2019-12-13 10:22:12.621
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=1,Fast=8.389700 | 2019-12-13 10:22:14.327
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.070000,Array_MACDP_Fast[sc.Index-1]=59.070000 | 2019-12-13 10:22:14.327
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=2,Fast=8.389700 | 2019-12-13 10:22:14.895
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.059998,Array_MACDP_Fast[sc.Index-1]=59.070000 | 2019-12-13 10:22:14.895
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=3,Fast=8.389700 | 2019-12-13 10:22:15.071
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.070000,Array_MACDP_Fast[sc.Index-1]=59.059998 | 2019-12-13 10:22:15.071
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=4,Fast=8.389700 | 2019-12-13 10:22:15.319
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.079998,Array_MACDP_Fast[sc.Index-1]=59.070000 | 2019-12-13 10:22:15.319
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=5,Fast=8.389700 | 2019-12-13 10:22:15.497
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.070000,Array_MACDP_Fast[sc.Index-1]=59.079998 | 2019-12-13 10:22:15.497
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=6,Fast=8.389700 | 2019-12-13 10:22:15.685
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.079998,Array_MACDP_Fast[sc.Index-1]=59.070000 | 2019-12-13 10:22:15.685
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=7,Fast=8.389700 | 2019-12-13 10:22:15.875
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.079998,Array_MACDP_Fast[sc.Index-1]=59.079998 | 2019-12-13 10:22:15.875
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=8,Fast=8.389700 | 2019-12-13 10:22:16.048
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.070000,Array_MACDP_Fast[sc.Index-1]=59.079998 | 2019-12-13 10:22:16.048
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=9,Fast=8.389700 | 2019-12-13 10:22:16.234
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.070000,Array_MACDP_Fast[sc.Index-1]=59.070000 | 2019-12-13 10:22:16.234
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Index=10,Fast=8.389700 | 2019-12-13 10:22:16.474
Chart: CLF20[M] 1 Min #1 | Study: MACDP Rev 1 | Array_MACDP_Fast[sc.Index]=59.072128,Array_MACDP_Fast[sc.Index-1]=59.070000 | 2019-12-13 10:22:16.474
Date Time Of Last Edit: 2019-12-13 16:29:52
[2019-12-15 17:58:42]
mm3599 - Posts: 15
Seems I did not remove and re-add.
Looks like I need to do that.
Thank-you
