Date/Time: Mon, 25 Nov 2024 01:57:19 +0000
Minimum PC requirements
View Count: 5394
[2019-12-12 15:34:40] |
AlekMiro - Posts: 4 |
Minimum PC requirements for installing a Sierra Chart terminal?
[2019-12-13 14:56:49] |
We provide some information about this here: Software Download: Requirements Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-15 12:41:23] |
User219661 - Posts: 1 |
Hi SC-Team, I have a follow up question regarding pc requirement. My pc doesn´t quite fit the recommended specifications as it has only 8 GB RAM. It has 6 core´s and a SSD though. I already tried out the free trial and SC is running very smooth and the RAM usages isn´t that high while I use it. Can I assume that it will be the same once I go live as I will use the same amount of charts(6)/windows(3) I am using right now? Would really appreciate if you could help me out! Thank you! |
[2023-05-15 12:52:24] |
Sierra_Chart Engineering - Posts: 17166 |
Yes this will be the case: Can I assume that it will be the same once I go live as I will use the same amount of charts(6)/windows(3) I am using right now? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-11 16:41:20] |
User384634 - Posts: 1 |
I have a macbook pro 2017 3.3 ghz dual core i7, with 8 gb 2133 mhz, when i ran with Wine and loaded TPO, omg... totally killed my computer, even when running on bootcamp. running it with 50 gig ssd dedicated didn't quite work for me. Now i have a subscription i can't use for my use case. Is the reason because I'm lacking rams? My experience suck so far
Screenshot 2024-04-11 at 10.38.16 AM.png / V - Attached On 2024-04-11 16:38:30 UTC - Size: 84.59 KB - 77 views Attachment Deleted. |
