Date/Time: Mon, 03 Feb 2025 20:59:20 +0000
I would like to install the previous version, which number / character do I have to enter?
View Count: 543
[2019-12-11 15:25:00]
User352963 - Posts: 1
I want to find an old shot that is no longer in the new version. I would like to install the previous version, which number / character do I have to enter to load a previous version?
I try: 2017 64-bit (29263M)
Now comes, as before the last 10 attempts:
"Installation completed whit errors.Refer to log and then press the Close button"
What should I do now?
Many thanks for your help!
regards
Maria
Date Time Of Last Edit: 2019-12-11 15:25:59
[2019-12-11 23:42:43]
If you want to install version 2017 then you just enter 2017 in the version box on the installer. Let us know if that resolves the problem.
