Date/Time: Fri, 29 Mar 2024 12:41:05 +0000
U.S. Equities (NYSE, NASDAQ, AMEX, BATS) Activation
View Count: 1530
[2019-12-11 14:31:53] |
Trader8188 - Posts: 20 |
I am currently setup with the Denali feed because I trade ES, CL, etc.. However, I would like to also trade stocks on U.S. Equities (NYSE, NASDAQ, AMEX, BATS). I want to add it without affecting my denali feed. Also, will I be able to see number bar (footprint) data on equities like NFLX, AAPL? Please advise me on how to set this up. |
[2019-12-11 23:32:18] |
There are two possibilities, you could stay with the Denali data feed and also add the Sierra Chart Exchange Data feed for US equities. Or use the Sierra Chart Exchange Data Feed for everything. In this last case it is best to do this by setting the Denali feed to not renew, then turn on the Sierra Chart Exchange Data Feed at the beginning of next month, so you do not get billed twice for the data from the CME this month. Refer to the information here for the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Set up instructions are on the above page. Let us know if you need any help. With the U.S. Equities data feed you will be able to use the Numbers Bars study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-11 23:33:02
[2020-08-03 13:15:23] |
User893396 - Posts: 38 |
Is it possible to use Sierra Chart Exchange Data Feed for CME/CBOT/NYMEX/COMEX ?I don't see it on the supported exchanges chart of the Sierra Chart Exchange Data Feed page. Date Time Of Last Edit: 2020-08-03 17:01:27
[2020-08-03 17:01:12] |
It is no longer possible to use the Sierra Chart Exchange Data Feed for everything. That message is older and does not reflect the current methodology. In order to get data for the CME Group and another exchange, you would need to use the Denali Exchange Data Feed for the CME Group and the Sierra Chart Exchange Data Feed for the other exchange(s). Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Using Both Denali Exchange Data Feed and Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
