Date/Time: Tue, 29 Sep 2026 00:08:19 +0000
connexion whith transact
View Count: 850
[2019-12-11 08:15:47]
User45578 - Posts: 50
i dont understant:im trying to intall sierra chart on my second computer and when i try to connect witn transact i get:Transact WS (Not enabled on package),while sierra chart is well running on my first computer with the same transact ,why that ,thanks
[2019-12-11 15:29:18]
It sounds like you are not logged into Sierra Chart with the account you have posted on this Support Board with. Make sure you are logged into the same account you have logged into this Support Board with. Refer to:
Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name
Also perform the Forced Login instructions here:
Sierra Chart - Software Login Instructions: Forced Login
Let us know if the problem is resolved.
Date Time Of Last Edit: 2019-12-11 15:29:28
