Date/Time: Sat, 12 Sep 2026 14:55:16 +0000
DOM scrolling limit - how to modify orders above/below?
View Count: 1073
| [2019-12-10 18:22:13] |
| T44 - Posts: 363 |
I place OCO orders by ACSIL. Sometimes the limit orders go beyond the limit of how far I can scroll the DOM up or down. There doesn't seem to be a way to edit the order price from the Trade Orders window. Is there any way to expand the amount of prices I can scroll in the DOM? If not, what is the recommended way to modify an order which can't be scrolled to in DOM? |
| [2019-12-11 03:31:33] |
There is a way: Chart Trading and the Chart DOM: Modifying or Canceling Orders that Are Not Visible on The Chart/Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
